It is currently Tue Feb 19, 2019 11:38 pm
Post new topic Reply to topic  [ 2 posts ]
 Post subject: SOLD! Rally-x / beater 2002 Subaru Outback - $2300
PostPosted: Sun Jan 06, 2019 3:31 pm
I bought this from Dustin's mom and prepped it as a beater and for rally-x ... never did make it out to an event, and I bought a new project car so it needs a new home!
2002 Subaru Outback wagon - $2300
Well maintained 2002 Subaru Outback wagon in blue with cloth interior. 2.5l 4-cylinder, 5-speed manual transmission, AWD, 194k miles. Runs and drives great, everything works fine, it needs nothing. I have done a lot of mechanical work on the car -- see below. Main issues are moderate oil consumption (~1 qt every 750 miles or so, but not leaking, no smoke), some rust, and a few dings and scratches.
The Good
- Runs and drives great, no error lights, everything works
- New KYB GR2 shocks and new shock mounts
- New transmission mounts
- Fresh oil in the engine, transmission, and differential
- New front brake pads and rotors
- New front control arm bushings
- Head gaskets and clutch were done at ~125k
- Very good tires with 80+% tread
- New trailer hitch and wiring installed
- Heated seats
- Straight pipe in place of rear muffler, sounds great!
The Bad
- Uses some oil, probably 1 qt per 750 miles. So check and add every other fuel stop.
- Rust spots at the wheel wells, was a northern car
- A little steering wheel vibration on the highway, probably just a tire out of balance
- Several dings and scratches, but the paint overall is pretty good with no fading.
- The driver’s floor mat gets a little wet when it rains, have not looked into what’s causing it. As a result it smells a little musty in the car if it’s not regularly driven
[img]https://lh3.googleusercontent.com/qhKMCgIYyDpaRTEZdJvWFELaz8q2ian2K-BB9RNMdH4OUfgDFz2TZqJfkPijVJhJ751_0-dVhTzO3QcRaUaJ1m_CBtJrB8KwSSaBhws011xDZmY9g9Cety9R_6x5TtiZvWzfyjFjbXFhgAeZfIn6m6xuAiAhbHVg-c0-KXHE39gbzvkzd9uO8ybAWNihhQISLxZHLfe7tV-v8UFdPXA9mZzlBcTvlVxlV6N5JjqEXwAqZH_m6t97rHr365lqityEBg6jcgrZUKZtyJ9LV_xVmWasEPn-decD2J79nJjIcUyJRbxuyJ9MSem2KPWMwPb0zGMiPL3H3t_VDI88O1f2Z9MCdT4ECNZkFPrVaZJFaAjdWx2NNZyg2EONOlq_HaiaUVCOXQYJe9aJAwDzIQ3nZAcCR3ZLTblom8xxAuoFZXHyUInj1UbcoBAdTYscinjifcu3dgrEnP1-8BtH185q4j0YYoXjQKXanJJE2FXiXUJsLHwWyMuHbQQqUsO3sOQrEwyq1cmBpOz-c2YRrPYQ4lWkLlYphg-r9RVAhdleqcJO8Ns7ZLXUeuOkUJqEVMvsX387guPcnmdNeyERT_QYiL-CW-08ouSkk6ukz5bcz2Aipb8YIN-37LYG1fcKTvyzsVvccdE111A6Xj6OqaYRSRnpXKvb476D6bFtVPdI6SlHY7xaSx-a57OPO6sc-T8uj5QnKKWAHfD37SaOefg=w1000-no-tmp.jpg
[/img]
V10, V8, I6, V6, I4, I4, I4, F2, I2, 1, 1
 Post subject: Re: Rally-x / beater 2002 Subaru Outback - $2300
PostPosted: Wed Jan 16, 2019 8:28 pm
SOLD
Users browsing this forum: No registered users and 6 guests
