1999 Mazda Miata with ~ 221k miles $2000 OBO - Members in good standing contact me.
Emerald Green Mica paint with tan interior and top
5 speed manual with torsen differential
BOSE stereo - CD player fails to read discs, but has bluetooth FM modulator to connect a smartphone
Engine does burn a lot of oil depending on how hard she's run. She's been run on a diet of Rotella T6 5w40 for the past 5 years and Mobil 1 or K&N oil filters. Paint is not the greatest, clear coat is failing on the rear bumper cover, trunk and hood. Lots of stone chips on the front bumper cover. Passed inspection last August.
Timing belt service with new front crank seal/cam seals, coolant hoses replaced, fresh coolant (Zerex Asian), ATE200 brake fluid flush - June 2016
Parts & ModificationsExhaust:
RoadsterSport 3 muffler (
http://www.good-win-racing.com/Mazda-Pe ... -1004.html) w/ baffled silencer for daily driving
RoadsterSport Mid Pipe (
http://www.good-win-racing.com/mazda/mi ... d=8TTBK6JG)
Raceland Stainless Steel Header (
https://raceland.com/mazda-coilovers/mi ... eader.html) w/ EGR Delete
Polyurethane exhaust hangers
Suspension:
Supermiata adjustable end links on all 4 corners (
http://949racing.com/SuperMiata-miata-end-links.aspx)
Racing Beat tubular front sway bar (
http://www.racingbeat.com/Miata-1990-20 ... 54103.html)
Racing Beat sway bar mount reinforcement (
http://www.racingbeat.com/Miata-1990-20 ... 54122.html)
ARP lug studs
Flyin Miata VMAXX classic coilovers (
https://www.flyinmiata.com/fm-nb2-v-max ... overs.html)
Wheels:
4x Konig Helium 15x6.5 with Dunlop Direzza Z2 Star specs 195/50r15 w/ 2/32 tread
4x Mazda Miata 14x6 with Yokohama iceGuard iG52c 185/60-r14
Brakes:
Hawk HP+ pads
StopTech front braided brake hoses
Flyin Miata Master cylinder brace
Wilwood adjustable bias valve
Transmission:
Flyin Miata 13lb lightweight flywheel (
https://www.flyinmiata.com/fm-13lb-ligh ... wheel.html)
Flyin Miata level 1 clutch (
https://www.flyinmiata.com/fm-level-1-clutch.html)
Flyin Miata clutch switch override (
https://www.flyinmiata.com/clutch-switc ... -2005.html)
Braided clutch hose
Delrin Shift Knob
Engine:
Aluminum Radiator
Racing Beat Intake (
http://www.racingbeat.com/Miata-1990-20 ... 56502.html)
AWR Racing engine mounts 70 duro (
http://store.awrracing.com/1994-2000-mi ... ine-mount/)
Thompson Automotive Oil Filter relocation kit (
http://www.thompson-automotive.com/relocation.html)
Fumoto quick drain valve
Body:
Robbins Tan Vinyl top w/ zip down rear window installed in June 2014
Hood Struts
Garagestar delrin door bushings
2001 miata seats reupholstered in black and orange
Brey Kruse Fire Extinguisher mount
2.5lb Amerex Halotron Fire Extinguisher
AC Delete - to factory specs
Sunvisor delete
Passenger sunvisor camera mount
High flow grill mesh
2013 Scion FR-S 10 Series - Solo Spec Coupe
Sold: 1999 Mazda Miata DD & CSP -
viewtopic.php?f=25&t=15327
