wow, I was thinking the other day I'd really like a 1/2 height lift for the garage. This "almost" fits the bill. There's no way I can permanently mount those lifts to the floor w/ my small garage. If this had some kind of portable support structure under it, I'd be all over this...
It has wheels on each post and a separate control unit. Each post is held in place with 5 bolts through the floor. The bolts go into expansion nuts imbedded in the garage floor. When you don't need it, you can roll it into a corner. I'm going to have to rent a hammer drill. The other part that I like is that it's hydraulic instead of screw or chain drive.
Vincent, It was about $400 less than a full height lift without the COSTCO deal. I wouldn't expect it to be much cheaper than that as a full height lift has about the same number of parts. The real difference is mostly material cost. I only have 9 feet in my garage and was talking to people about building a garage. I think that Nancy figures that the difference in cost is hers or she wants me out of the house an in the garage. BTW, most of my work is changing tires and brakes, so the height works for me.
