I replaced my drivers seat with a tillett so I am selling my kirkey seat. I cut the cover where the stock 3 point belt was run to make swapping it with poured inserts easier. I can also include some aluminum brackets that I made for the seat that will fit the stock seat belt receiver.
$100
I also have an expired cobra suzuka GT kevlar seat. I wasn't able to fit it in my car after adding door bars. This is a wide seat (which I thought would make a great passenger seat). It includes cobra side mounts. $200
350mm momo steering wheel with horn retainer ring, horn button, 1" spacer, and I have some grade 12.9 20mm long socket cap screws (too short if you use the spacer) I can include. $50
I also have:
*Never been used sparco sliders, I pulled them out of the packaging for test fitting but they have never been mounted. $20
*NA miata headlight motor assemblies with stock lights in them (no headlight lids) $100
*Black cloth miata passenger seat in good condition $75
*NB miata front sway bar 22mm $20
*NA miata OEM turn signal lights $30
2001 VTCS intake manifold free with any purchase
